Anyway. I've gone and ordered the 507 kit
what have I done!
what have I done!
what have I done!You’ve done the right thingAnyway. I've gone and ordered the 507 kitwhat have I done!
I got some pics for you. It takes me about 10 minutes to make it mobile (empty of course) once you have the right bits of wood etc. Once you've moved it a couple of times it easy to do. Moving it using the pump/motor unit is very difficult but possibly. Using a small trolley jack you only have to worry about pulling it along not pressing down as well. The swing out arms are located in slots on the inside of the lift main body. The rear ones are 30 cm long and the fronts around 18cm. The arms can be lifted inboard of the stop pins but you should never lift in that position.@t-tony Looks like I'll be going for one of you PS3600 lifts after all. The whole thing is around 350KG? is that correct?
How easy is it to move around? I can do some work in the garage but, on nice days I'd maybe like to drag it out onto the drive. Is that feasible?
Another question, if I may. Those swing out arms. How far back and front do they reach? I always liked to lift a car via front/rear cross members, suspension mounts etc rather than the actual jacking points. Just wondering.
Here's one. Wheels. I'm going to need fatter wheels aint I? I don't like spacers. Really won't put them on the front.You’ve done the right thing
Happy to help if you have any questions
Hey @Nodzed I hope you don't mind me popping this post back to the top. I wasjust looking back and notice that this tilting lift doesn't even sit on the jacking points? Do you have some extra extension under there?I guess it depends on what you want from one.
I have had 3 so far with mixed results. All supplied from Automotech, prices on their website are plus VAT and delivery.
Links added full specs are there.
#2 Automotech tilting Scissors Lift
Was a tilting manual lift, really couldn't get on with it, great if space is limited but found it an awkward system.
Got rid of it years ago but I'm fairly sure it sat on the chassis not the jack pointsHey @Nodzed I hope you don't mind me popping this post back to the top. I wasjust looking back and notice that this tilting lift doesn't even sit on the jacking points? Do you have some extra extension under there?
How it attaches. There's 3 screw holes. Can't see innthe picture. Also a bracket which I may or may not use.They look very nice, but three observations...
How does the rear part attach?
The nose looks like it would go into the door skin when you open the door. Am I wrong, or have you thought about this?
The handle doesn't open in a straight line. Does your design compensate for this?
I just had a closer look at it. There appears to be a bit of a gap of couple mm at the very front tip of the handle which allows the lever to rock without digging into the door. Gap means muck trap so something i need to think aboutThe nose looks like it would go into the door skin when you open the door.
I've got it. It sits on the area by the sills, but not on the sills (if that makes sense). I use the back of the front jacking point as the datum for the jacking plate, and put 50kg in the boot to balance the car. If you don't balance the car, it is very heavy to lift.Got rid of it years ago but I'm fairly sure it sat on the chassis not the jack points
I was just talking with the guy at Automech about his various lifts.I guess it depends on what you want from one.
My garage isn't wide enough to slide it in from the side. I was thinking of ways to make drive over ramp.I've got it. It sits on the area by the sills, but not on the sills (if that makes sense). I use the back of the front jacking point as the datum for the jacking plate, and put 50kg in the boot to balance the car. If you don't balance the car, it is very heavy to lift.
It's an awkward beast to move around, but it's very good to use when the car is on it. You either need a method of driving over it, or a space beside your car that is wider than the car, as it slides in from the side.
I think your lift will lift 1.3M The Z3 is 1.3m high so lifted to the full height of your lift without the additional block the top of the Z will be at 2.6m That's 0.5 beyond the height of my garage below the mezzanineWhy. It is designed and made to work to its limits. 210 cm = 2.1M head room, so with a car on it you”re only going to lift the car about 4ft off the ground?
