There was a Matra Simca Bagheera parked in the Gill at Ulverston there for many years it was white with a chequer trim not sure if it is still there next time i am around there i will have a look
I never knew that. Makes sense though. I don't think the 1600 had much more HP than the 1442 with 2xtwinchoke webers. 90+I think. But 1600 would be more torque. Longer legs for those motorway business miles.. . . . at that time Company cars needed to be at least 1600cc to make the system work . . . .
The first mk1 bagheera had the 1294cc engine. Later came the 1442cc engine which was the same as the Alpine/Solara although a 1600cc came even later but that never got into a bagheera (except mine). The 1600 was the engine used in the murena which replaced the bagheera. Personally I never liked the murena even tbough it was a much better car.So did these have the same engine as the Talbot Solara ? I remember in the mid 80s when we all had modified minis and escorts someone turned up in a Talbot Solara at the usual Friday night traffic light Grand prix and wiped the floor of us
@t-tony Looks like I'll be going for one of you PS3600 lifts after all. The whole thing is around 350KG? is that correct?I took my car out this afternoon and took these pictures. This type of lift has 2 rams which only restrict access at one end, so depending which way you load the car you can have good access.
You can get almost free access to the sills depending how high you lift the car, there are multiple choices here.
View attachment 275783View attachment 275785View attachment 275787View attachment 275789View attachment 275791View attachment 275793View attachment 275795View attachment 275797View attachment 275799View attachment 275801View attachment 275803View attachment 275805View attachment 275807
The easy way to get good clearance is to lift the car directly off the floor, (on standard suspension you don't need the wooden ramps to clear the lift). So lift the car about 18" and the place an upturned milk crate under each wheel. Lower the lift back to the ground leaving the wheels on the milk crates. and place as many lift pads on the arms as you need, then lift again.
You should only drive with the roof down, so lining isnt required.Back to my 507 rebody questions. Just for a moment
My z3 softtop is very noisy. Road noise etc. Does the lining, in tops that have it, make any difference to road and wind noise or is the lining just cosmetic Can lining be added or would I need a whole new top. Is it worth it just for the lining if it doesn't make any real difference.
Can power raise/lower be added to a manual hood?
If I want power and lining Is it better to change the whole thing? Metalwork n all? Seeing as how I fancy a color change too.
I really like my z3 OEM Hardtop and will attempt to mod it to make it fit the tribute 507 body. Might wreck it but happy to try.
I will do some measuring tomorrow when it rains for you.@t-tony Looks like I'll be going for one of you PS3600 lifts after all. The whole thing is around 350KG? is that correct?
How easy is it to move around? I can do some work in the garage but, on nice days I'd maybe like to drag it out onto the drive. Is that feasible?
Another question, if I may. Those swing out arms. How far back and front do they reach? I always liked to lift a car via front/rear cross members, suspension mounts etc rather than the actual jacking points. Just wondering.
