Dxbolton
On a wide body the wheels Are tucked under quite a way, which is why so many people use spacers
With all that rain, you want to check it for rust when you get it
Oh. The water. That's intentional. I asked for the 'wet look' version.With all that rain, you want to check it for rust when you get it![]()
It's got to be in the region of 100kg. I know the diff is 40kg.How heavy is the back axle, the whole thing trailing arms, beam and diff? Just wondering what kind of bench I need to roll under the back of the car to drop the back end on to.
What is the make/model of your car on your insurance? If you don't mind me asking.Have a word with Adrian Flux, very helpful and they deal with lots of kits and of rebodies. My Tribute is £150 a year limited to 5k miles, when you are an old bugger like me the engine size doesn't make much difference in the premium.
My V5 has "Tribute California" in make and nothing in model, they seem to be a bit hit and miss but I was pleased that it doesn't mention BMW so I can technically say there is no build specification available to say that it should have an air bag. OK so a bit iffy but I have never had it mentioned at an MOT but was told that if it had been registered as a BMW ZS3 then it would fail on the air bag. Leave the air bag wiring in place and then you could always fit the original steering wheel at a later date if you need to.
You can change the details of the V5 on form V627/1, this you can download. Give them the least information possible, just stops them asking more questions.
It is important that you have before photos showing both front and rear with the numberplate clearly visible, also a photo of the VIN, use the one stamped in the bulkhead behind the engine, the one in the window is just a sticker.
The renaming is just that so keep it simple, you can place your body kit in position and take some photos of front rear and both sides showing the registration number clearly and a photo under the bonnet showing the Vin number. If it has lights etc attached even if not connected you can send the photos and form off with the new colour as grey, it's just a job out of the way and one less thing to worry about.
