wheel spacers
mini
Folks whats the opnion on them for a standerd 1.9 zed , standard suspension eith 17 wheels ?
Mine is a 2000 2.0 on 17's. I recently fitted 12mm on the front and 20mm on the rear.
Hi, I got mine while on holiday in Florida last September from an ebay seller because I saved about £35 p&p by getting free shipping from California to our place. They then came home in my suitcase! The seller was called venomwheelaccessories. Very helpful when you contact them.
http://www.ebay.co.uk/itm/251547666591
ps. They are the "hubcentric" type which is the best type to fit.
pps. Have a look in GadgetZ, Gizmo'Z and Bling section under the forums tab. There is the post from when I fitted mine.
Brian H
Killin
E36/7 3.0i - E85 Z4///M
Fit Hubcentric ones as Tony has stated, looking at your pictures you will not need a huge spacer to push the wheel out, best bet is to measure the gap between your rear wheels and the rear wing, this will tell you which width spacers you need.
A little guide to help :) http://www.turnermotorsport.com/t-wheel-spacers.aspx
Brian
mini
Thanks I've kinda picked what to do on size ops , and noticed the make hubcentric on eBay . Cheers
