Latest update:
www.perfect-touch.co.uk
Great service by a quality bunch of mechanics. I can recommend this place, take a look
VANOS refurb,
Seals and rattle ring (whatever that is
Cam Cover gasket
Viscous fan coupling
Coolant
Sundries
£571.91 all in (less 2.5 tanks of fuel, Premier Inn, trip into London Imperial War Museum, food).
709 mile round trip to Hoddeston in Hertfordshire with the drive back being better than the drive down, just seems to run smoother, which is nice
On the up side the guys did a full top to bottom and boot to front inspection (all these, bar 3 points, missed by a BMW Main Dealer recently)
This is the down side
O/S/F fog light unit corroded (new that)
Only one horn working
Centre Exhaust Clamp broken but not blowing
Advise changing rear wishbone bushes for Powerflex as becoming weak
Front brake pad sensor damaged and not connected
Off side washer jet broken, leaking from base
Noise from gearbox, possible release bearing
A/C not working
N/S/F wish bone outer and inner ball joints worn
O/S/F wishbone inner ball joint worn
Small oil sweat from gear selector seal
Small oil sweat from oil filter housing
Front lower RAD cover tray broken and held up by cable ties
N/S/F and O/S/F inner arch linings damaged.
Should keep my local Indie in holidays for a while
Oh, this Z4 ///M was up for sale outside;
