I used to do painting years ago with cellulose, you didn't need much heat to dry it. None in the warmer weather.
Does that mean you smell?I can't even make a decent job of spraying my antiperspirant under my arm pits !![]()
Cheeky !.....that's why i had to get an open top carDoes that mean you smell?![]()
Brian, there is a small gap between the outer sill and the chassis, this allows dirt to build up and it gets trapped around the plastic jacking points, it acts like a sponge and holds waterHi and welcome. Interesting read . Looks as if sills need checking mine were a bit rusty and another here had a patch put in so a weak point hiding behind the cover and the plastic jacking points.
No Dave, it was when Ant, Andy, Roy and me went to the Rose and Crown at Upton, we passed it when we all went for the run. We met a couple there with that car, nice pair from Yorks.Very vigilant Tony, I assume you meant when we were out with you?
Coincidence Tony?No Dave, it was when Ant, Andy, Roy and me went to the Rose and Crown at Upton, we passed it when we all went for the run. We met a couple there with that car, nice pair from Yorks.
@Antm72 , @Andy McDonnell and @Rha does this look like the Z we saw at the Rose and Crown that Sunday with that couple from Yorks.? I recognise those stickers above the side gills.Here's the original pic of the Z shortly after purchase, we have a long journey ahead, but its all original with no modsView attachment 24427
Very much so Tony, sure is was a "V" reg too?@Antm72 , @Andy McDonnell and @Rha does this look like the Z we saw at the Rose and Crown that Sunday with that couple from Yorks.? I recognise those stickers above the side gills.
So you did Tony, had a couple of hours in the workshop today, finished the prep of the os sill and stone guarded it, that is now ready for painting as is the os front wing, stripped the grills and gills off the bonnet and did a bit more work on it, thats about it for today, still in turmoil over the colour but nailed it down to 2 options, swatch a or swatch bMust be the one Sean. Amazing, we saw your car before you did.
Yep....swatch a
