Raised front suspension or heavier load
Marquisz3
North Carolina
V8 roadster
Sorry for the spamming of these forums with random topics gents, as is with a big project like this I run into random questions and issues, context I put a 350sbc into my z3 and have slight front sag issues
first photo from a bit ago when on stock rears
Currently with the Hoosiers
they don’t necessarily need to be track oriented or even a whole set the primary goal weather through weight rating or height would be just to lower the front maybe an inch or so?
The front end is fully e36, so front coilovers from any model fit straight on a Z3 .
The springs should vary from 4/6 cyl, in reality only the expensive ones have different rates from model to model.
If fitting used ones, wind down the collar fully, remove the spring and make sure the strut still has damping in both directions. Wire brush the threads and use a silicone, or ptfe spray, they dry without being sticky, stops dust collecting and clogging the threads.
If you want to adjust the camber cheaply, add hard washers and use slightly longer bolts in the lower mount. Just don’t add that many you lose engagement of the locating nipple.
Probably a good idea to fit reinforcing plates, they’re easily available both new and s/h, they’ll gain you 3mm, 1/8” on their own.
Marquisz3
North Carolina
V8 roadster
Thank you for this I was under the impression they were from an e30 for some odd reason
Marquisz3
North Carolina
V8 roadster
Probably gonna order these now any thoughts on if I should change the springs and if so any reccomendations it’s from a 6 cyl model
Bit of 2 Bmw
The rear end is E30 but the front is E36
The multi link E36 read end was too large to fit it the proposed z3 platform so the older E30 semi trailing arm set up was used as it was more compact.
Dont know if you got these in the US but in UK and some European countries we also had the bmw compact
Sane underneath as our Z3 hatchback 3 series styling and badging
Sold as a 316, 318 etc compact.
ChrisD
Vale of Evesham
M44
Bit of 2 Bmw
Both the front and rear of the Z3 are essentially E30. Amazing to think that the suspension design is well over 40 years old on our cars. Adds to the nostalgic feel, I think.
Delk
Hemsby Norfolk
Z3 3.0T
You can get cheap coilovers off ebay and set the height as you want. They do ride harder then rocks and are to be avoided but if you need cheap and chearful they are avaible.
Marquisz3
North Carolina
V8 roadster
Bit of 2 Bmw
I haven’t actually seen one of those in the us before but I went ahead and ordered some stock front shock and springs from a 6 cylinder e36 should also be way better because my current front suspension is for a 4 cyl so the weight from the v8 is definitely a bit much for it and got the reinforcements so I’ll post an update on how it fixes the sag when it gets here
Marquisz3
North Carolina
V8 roadster
My biggest issue was just only finding the fronts, ended up going with what he mentioned and found oem front shock from a 6 cyl e36 (super happy with the rear ride height genuinely just concerned by the sag in the front from a height perspective
Marquisz3
North Carolina
V8 roadster
Update got used e36 6 cylinder shocks and it fixed the sag and ride quality entirely
if anyone else ends up with a v8 swap on a 4 cylinder model I highly recommend the 6 cylinder e36 shocks if you just want a budget oem setup
