Nothing to see here, especially Andyglym.
bertiejaffa
Manchester
Z3M
Its caused by wet carpets - lift the seat - the carpet is in 2 halves with the seam under the seat, put your hand through the gap and I bet the foam is sodden. only way to sort that is to take the entire interior out and then find the leak.
Rod and Kate
York
2.8 Z3
Ok mate will check that out, however there's no musty or damp smell in the car. Thanks for that though, didn't know that. Cheers.
bertiejaffa
Manchester
Z3M
No worries pal - that will all just wipe off with Milton as someone suggested. Leaks can come from anywhere, on my old one I emptied the entire cabin and it turned out to be the seal on the A pillar, not where the roof joined the car as I initially suspected.
I also use the condensation bags in winter as well.
Pauliebhoy
Argyll
Z4 G29 20i
That happened once to our Z3. We never did find out how it happened although in subsequent years we left disposable dehumidifiers in each foot well and in the middle console as well as the boot. Mandy used astonish mould and mildew remover sprayed onto a cloth to remove the mould, cleaned the carpets then cleaned the car as normal. It never happened again.
