Better in the shed than on the drive home i say
What paint are you using?So got the underside of the callipers painted, just waiting for the paint to dry and I will do the top.
Andy
What a shame but better to have gone there than on the road. These things come to try us sometimes, they are old cars now and do test us sometimes. Hope you've got it all sorted now.They look great fittedAndy dropped down to the shed today to have new wishbones fitted, and brought the calipers and new discs with him. Actually the wrong sized discs, but a quick drive to ECP to switch them over and we were OK!
New wishbones...
New calipers, discs and pads...
Braided brake lines too.
Sadly as this point we sprung a leak. Brake fluid started flowing down from behind the arch liners. After removing the arch liners and plastic covers we found that the copper brake line had ruptured. The rupture is hidden away so unless someone noticed the brake fluid leaking it would have gone unnoticed until it split while braking. Scary...
Andy has just gone to halfords to buy some brake line, flaring tools and more braked fluid.
That would be the original steel pipe going by the corrosion?They look great fittedAndy dropped down to the shed today to have new wishbones fitted, and brought the calipers and new discs with him. Actually the wrong sized discs, but a quick drive to ECP to switch them over and we were OK!
New wishbones...
It would only have been a matter of time before a nasty brake fail, so a pain it happened but happy it did really. Could have been rather scary and no happy ending.Better in the shed than on the drive home i say![]()
FYI, The 3.0 has 300mm discs as standard so same size as the 325i/sBit of a schoolboy error on the brakes, I got E46 325 callipers when I should have got E46 325i/s callipers.The 325 are 286 vented same as the 2.8/3.0 and the 325i/s are 300mm. So should be a marked improvement in braking and with the braided hoses even more so, at some point will go with Red/Yellow stuff pads as well.
Andy
Providing the rest of the steel pipe is in good order there's no reason the replace it. Perfectly good repair, most cars have joints in their brake lines.Back in the 'shed for a rare Sunday session, but we can't leave Windy stranded 90 miles from home can we.
A temporary fix has been completed, and Andy will source proper replacement lines on his return home.
Cut back the rotten section to a clean undamaged section, and replaced the whole section up to the where the brake lines are attached.
This pic is a bit dark, but you get the idea!
This is a better close up view of the line we took off.
Andy is going to have a slow and steady drive back home tonight!
Excellent service guysBack in the 'shed for a rare Sunday session, but we can't leave Windy stranded 90 miles from home can we.
Looking very smart Amdy
Thanks Tony, interesting to know... and I'm not necessarily surprised that it happens.Providing the rest of the steel pipe is in good order there's no reason the replace it. Perfectly good repair, most cars have joints in their brake lines.
