So between projects we fancied getting our hands really dirty! and it just so happened my mate offered me his wife's car that just shredded its cambelt and chewed a few valves. Also another good way of injecting cash into the zed shed tooling budget.
So here she is: Audi A2 1.4 petrol. 90,000 on the clock. (sport)
Pretty tidy car, all straight and fully working (bar the engine)
First things first was moving a non running motor 50 miles safely.
This beautiful bit of kit is rated to 3.5 tons. Its a fixed A frame attachment that requires no second driver it clamps onto the wishbones. The car on tow just freewheels and steers as per the car in front. (P.S open for the Zed community to use)
So first on the list was to get the head off and see the damage. It was clear from the off by the state of the belt what we might see.
The first line of thought was to inspect the internals. 1) see how many valves were bent 2) see if there was any damage to the pistons.
So just over 2 hours in we had the head off. Interesting setup as the cams are the rocker cover in one. Which once removed show the tops of the valves. Then you can remove the head.
We did a simple leak test on the piston heads with some fluid and found none lost any. But we did see a score in one cylinder but once you look closely its clear it had been present for some time.
Now you can see the state of the valves 8 out of 16 have met the pistons (for those not to mech savvy the valves should sit flat/flush)
So this is the aftermath of an afternoons work
We have decided to replace the head instead of replacing the valves, This is because of the cost vs time. We also have an unknown on the condition of the head, it could be cracked or the valve guides could need replacing which we can't do in the shed.
Updates to follow soon
Thanks go out to @pgunter @Oldguysrule It was a team effort again.
