Which Way in Does ECU go in
Plug at the front of the ECU box
Chamber66
Swansea
Not the plug bit, but which way around does it fit back in the box.
I struggling to get it back in either way and dont want to damage anything
As I said with the plug facing the front of the ECU box, so as your photo turn the ecu forward so the plug is facing the front of the car and insert it in to the ECU box, it is a tight fit.
Chamber66
Swansea
Sp I am trying to fit it wrong way up.lol
Im tryingvwith the plug at the top doh
I normally take pics but didn't this time
Chamber66
Swansea
Justvto confirm the sticker at the top and the connections to the front
Not sure which way the sticker goes give me 5 and I will go take the cover off and have a look
As your photo rotate the ECU 90 degrees forward and that correct. The wires from the plug sit across the top of the ECU when in place.
Cant see a sticker so assume its underneath
