Torque pro/lte layouts
bombur
Porthcawl, Wales
Z3 1.9, Z4 E89 2.3
Anyone out there using torque pro whilst driving? What layout are you using- what dials/graphs are good to have? Coolant temp is the reason Ive set it up but what others are useful? Dont need 0-60 times etc as I have a 1.9 lol
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
3.0L, 2.8L, 2.0L Z3 Roadsters
Short term and long term fuel trims are fun to monitor. You'll soon see if you have any vacuum leaks.
Battery Voltage is another useful one to have on a secondary screen. Allows you to check that the Alternator is working OK.
bombur
Porthcawl, Wales
Z3 1.9, Z4 E89 2.3
@NZ00Z3 mine stopped working , only worked the once, ordered another and the same 9will return that). Ive heard its hit and miss with them. Which adapter are you using?
Alan @handsomejackuk uses it plugged in when driving he is on the Zed Shed Cymru Group
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
I use a IKEGOL Super OBD WIFI dongle as I'm run my OBD2 app on an iPad.
The dongle gets hot when it's on for a long time.
Also note, that the power supply in the OBD2 connector is "Hot All the Time", so leaving the dongle plugged in when the car is not being used will drain the battery.
