Ok so had this Z3 a year now and this is the jobs I have done so far......
Greased up the windows with grease on the metal parts and silicone everywhere else!
fitted a new aerial grommet
cleaned up the spare wheel and carrier
cleaned up and painted under the rear of the car
fitted polly bushes to the front rear wishbone bush
fitted new rear drop links and cleaned and painted roll bar and brackets ect
flushed then changed oil and filter ect even new and better little O-rings on the long bit in the oil filter lid
new seals in the VANOS
changed the old front tyres for Goodyear's F1's as the old ones were 7 years old and cracked
fitted new disks "Mtec grooved drilled" with new pads and new shoes cleaned up and painted callipers ect
new stainless steel exhaust with cats
changed MAF and inlet pipes and cleaned idle valve
changed the oil breather system also dipstick O-ring ect
changed fuel pipes and filter ect 8/6/16
cleaned up and painted power steering pipes epoxy paint
Windscreen / done
water pump 18/10/16
thermostat 18/10/16
tensioner 18/10/16
Aux Belt 18/10/16
Antifreeze change 18/10/16
seat bushes 9/3/17
heated seat fixed 9/3/17
seat bolsters fixed 9/3/17
dye the seats 9/3/17
and next is
brake pipes
fix the rust and spray the car
rear F1 tyres
Windscreen / done
water pump 18/10/16
thermostat 18/10/16
tensioner 18/10/16
Aux Belt 18/10/16
seat bushes 9/3/17
and next is
brake pipes
rear F1 tyres
