No headlight or screen washers on E89.
IvorZ3
Suffolk
Z3 2.2i
Hi , both my screen and headlight washers aren't working on my E89 . The fuse seems ok.
Any ideas on how to proceed much appreciated.
There are separate pumps for the windscreen and headlights, so unlikely both have failed at once.
Check fuses 1 and 3 in the engine bay (both 30 amp).
If not a fuse probably gunk blocking the outlet to the bottle.
Firstly I would check that both pumps run. They are attached to the washer bottle near the bottom. You can hear them with the bonnet open if you get someone to activate them inside the car. If both work, I would syphon out as much water from the bottle as possible and pour some diluted milton fluid into the bottle and wait for a few hours to see if it clears.
If that doesn't work, it's a case of taking the washer bottle out and checking for blockages.
B21
Scottish Borders
E89 35is
What does your BMW specifc fault code reader say?
IvorZ3
Suffolk
Z3 2.2i
The scanner comes up with the code : A6D3 (Windscreen washer pump) and A12D (Light sensor so a different issue)
