Expired Maf intake hose
Davyhoogy
Sunderland
'98 2.8 z3
Just been for a drive to drop the car off at the garage and it ram very lumpy.
Suspicions of maf hose split confirmed immediately.
Anyone have one they can send me or know the best replacement pattern one on eBay for 15quid but don't know the quality.
Cheers
mrscalex
Swindon & Swansea
Secondhand is a bit of a false economy. They usually show signs of deterioration. And they aren’t cheap usually. Around £15 against £25 new from BMW.
I bought a 3.0 part from d2pautoparts10 on eBay. It’s okay but was a tight fit to keep properly in place. But then I don’t know a new BMW one wouldn’t be the same.
The lower hose is only £15 from BMW anyway. You should check that too.
You can also bodge up the leak with some black silicone sealant. That’s a good temporary repair if the hole isn’t too big.
Davyhoogy
Sunderland
'98 2.8 z3
It's too big...
I don't know how it wasn't running badly before
Brian4
Near Grantham
Z3 3.0i Auto
Black tape does a reasonable quick repair and then contact Sopers bmw for a replacement. Cheap enough for a genuine part.
mrscalex
Swindon & Swansea
Yep that’s a gonner. I would definitely check the lower (throttle body) hose too if the top one is so knackered. People often say they are a b*gger to get off and on but there is 1 place where the screwdriver fits just fine and that's good enough.
Davyhoogy
Sunderland
'98 2.8 z3
Might be a good idea just to get all new hoses while I'm throwing money away then I don't need to wait for them to rip
Z3I
Weybridge, Surrey
Fiji green 2.8
I've just bought the 2 new hoses and new clips all round for £47 from BMW. My car failed it's emissions on a split on the lower hose. Avoid rubber products on eBay, usually made of low quality Indian rubber, won't be long before they split again.
Sean d
Lincolnshire
I recently replaced the lower hose Robert, found it easy to take the main hose off, and replace them as one piece
Mario
I have bought Febi intake hoses in the past and no troubles. The ones from the dealer I put 3/4 years ago were toast last time I looked, maybe my engine bay is too hot.
Davyhoogy
Sunderland
'98 2.8 z3
Looks like it been chewed by a rat mate, I bought a £15 one off ebay and it was great quality.
Is this the right one? Not sure and I've tried looking on realoem.
I have no idea about the lower one but if you have a part number that would be a big help :thumbsup:
mrscalex
Swindon & Swansea
You've got to be careful as the part number is wrong on realoem for 2.2s at least. It's best to look on the old part in this instance.
Sp02zbr
If you go to bmw. You need to ask for the one for the 5 series bmw. As that’s what we found when looking.
Top hose is correct for one of them. Just never bothered changing it. Seems like hassle.
Bottom one is the one they give you if you ask for the 2.2 one. It’s wrong
Davyhoogy
Sunderland
'98 2.8 z3
View attachment 87255 If you go to bmw. You need to ask for the one for the 5 series bmw. As that’s what we found when looking.
I have a 98 2.8 though will they all be the same?
Sp02zbr
I’m not sure. I was only replying to the guy who mentioned a 2.2
If it’s the bottom one you need. You can have it
