Hello from Belgium with a 1998 1.9
Gauthier
Belgian Zeds
'98 z3 1.9 m44
Hello everyone,
About a year ago, I became the proud owner of my first car: a 1998 BMW Z3 in Arctic Silver, featuring the brilliant M44 engine and a manual transmission. It had 167,000 km (103,000 miles) on the clock, and from the moment I saw it, I knew it was the one.
My love for the Z3 started a few months earlier when my uncle lent me his 1996 1.9 automatic for a road trip to France. That week behind the wheel was all it took, I was hooked. I had to get one of my own. Ideally with the M44 engine, not just because Belgian taxes on six-cylinder cars are steep and insurance for someone my age isn’t exactly cheap, but also because the M44 has a lively, lovable character that suits the car perfectly.
After three months of searching for the right spec with a solid history, I found this gem. The silver paint is beautifully complemented by the red-and-black sport seats, which were a must-have for me. The M-sport steering wheel was another welcome bonus. Heated seats are wonderful in spring and autumn. Unfortunately, it didn’t come with a limited-slip differential, but you can’t have everything in life I guess.
Thankfully, the previous owner had already done extensive engine work, including:
  • Replacing the head gasket
  • Servicing the intake and exhaust valves
  • Replacing the timing chain
  • Installing new piston rings
  • Replacing the connecting rods
  • Installing a new crankshaft
  • Replacing the crankshaft bearings
  • Resurfacing the cylinder head
  • Replacing the valve seals
This gave me peace of mind. The body was in decent shape aside from some stone chips and light scratches on the rear bumper. The soft top was in excellent condition, and the interior showed only minor signs of wear.
I went to see the car together with my father and took it out for a test drive. It felt right straight away, and I was sold. The owner agreed to have it inspected (similar to an MOT) and to take care of the issues that came up. One of them was the X-brace, which had corroded badly and even had a hole in it. He replaced it before handing the car over, which gave me extra confidence in the purchase.
A few weeks later, I traveled across the country to pick te car up, several train rides and a drive with the seller later, I was finally face-to-face with my Z. I drove it home without a hitch.
Here a picture of the first week at home:
And the lovely sport interior:
But a few weeks later, trouble struck: coolant started leaking at an alarming rate. Turned out the expansion tank needed replacing, in the end a whole new radiator went in. They also fixed a small leak in the rubber power steering fluid lines by replacing them and tackled the surface rust on the brake lines.
After that, the car went into winter storage. When spring came, it fired right up, and I was able to truly enjoy it over the past year.
Next on the list were the tires. It came with 11-year-old 205-width winter tires, not ideal in terms of performance or looks. After some searching, I found a set of Style 18 wheels with newer Dunlop summer tires. They offer much better grip and look far more fitting (the arches are much better filled). The ride is a bit firmer now, but the benefits outweigh the trade-off.
Looking great on the style 18's.
( Yeah, the number plate holder isn’t aligned properly, and it annoys me as well… )
I also did my first bit of maintenance myself: oil change, oil filter, air filter, and spark plugs. After driving over 5,000 km (3,000 miles), I’m still absolutely thrilled with the car. It’s now back in winter storage, waiting for the next season.
Cleaned and ready for winter (I also put it under a cover):
Coming up: new brake discs and pads (the steering wheel shakes slightly under hard braking and pulls to one side), replacement of the worn-out handbrake shoes, and a full suspension refresh (bushings and dampers, maybe lowering it so the arch gaps close in even more...). The headlights also need polishing, as they’ve become a bit dull over time.
I hope to continue documenting more of my journey on this forum.
Kind regards, Gauthier.
Hi and welcome to the forum :welcome:
Great write up as your introduction :thumbsup:
Gidday from Australia
Krystian5156
Scunthorpe
E89 35i
Hi Gauthier,
Really enjoyed reading your Z3 story. I hope you’ll keep posting updates from time to time — projects like yours are always great to follow. As with any love story, things can get difficult at moments, but that’s probably why every Z-series owner smiles when they spot another Z on the road. At least that’s how it is for me — instant grin 😁
I’ve had my fair share of adventures with these cars as well. I’m currently on my third Z4, and they’ve definitely taught me patience when it comes to repairs. I drive around 20k miles a year, and for the past three years I’ve been doing that in a Z4, so you can imagine the lessons learned.
One thing these cars made me understand is: when you fix one thing, think about the components around it too. These are older cars now, and they deserve proper care — and in return they make us feel exactly why we love them so much. Always with a smile on our face 😁
Best regards!
Althulas
Banburyshire
M Roadster
Hi Gauthier, how times have changed. Not bad for your first car and just as easy to work on compared to a Mini which I started my car journey with. There’s lots of good documentation in the Zedshed section to help out with suspension refresh and if you go as far with the rear beam bush replacement.
Gauthier
Belgian Zeds
'98 z3 1.9 m44
Thanks a lot:cool:
Now that I see your name here on the forum, I vaguely remember the mechanic telling me that the fuel tank straps looked rather rusty and were due for replacement in the near future. My question is: are these still available? I’ve only ever read good things about them here on the forum.
Gauthier
Belgian Zeds
'98 z3 1.9 m44
Hi Gauthier,
Best regards!
Thanks! I also really enjoy reading posts like this on the forum, so I don’t want to fall behind the rest, haha. These cars are getting a little older, and I know that eventually everything will need replacing. Still, I’d like to postpone a full restoration for now—step by step we’ll get there.
I can relate to the joy of spotting other Z3s on the road; it always makes me smile, and I never miss the chance to wave or give a thumbs-up. I’ll try to keep the forum updated with my progress, but for this winter there’s nothing major planned. But reading the posts in Zedshed is starting to make my fingers itch as well...
Gauthier
Belgian Zeds
'98 z3 1.9 m44
It’s still very much a “hobby” car for me. At first, I was actually looking for an E30 318is, but finding a good one at the right price has become nearly impossible here in Belgium. So the next best option was the Z3 1.9 with the refined M44 engine. I have to say, I haven’t regretted that choice for a single second—the open-top driving in summer is simply fantastic.
Having driven an E30 318is as well, the differences are clear. The steering ratio is much longer lock-to-lock, which makes it feel like a truck when taking sharp corners, the big steering wheel doesn't halp either. The gearbox throw is also longer, while the seating position is a bit less ideal. The E30 did feel more precise overall than my Z, but that was probably thanks to its freshly renewed suspension with a Bilstein B12 kit, maybe something I’ll consider as a future upgrade for my Z3 too.
I’ve been reading a lot of posts in the Zedshed recently, and I’m planning to take a closer look at the rear beam bushes. I’ll put the car on a lift at a friend’s place to properly check the condition of the suspension. I wouldn’t dare tackle it on my own, but with the help of my friend who has plenty of experience with E30s and E36s I’m confident we’ll manage.
Hi Gaithier,
Tank Straps available any time you need them
Just send me a PM. ( personal message)
( just hit the envelope icon )
Hi Gauthier and :welcome: to the forum from me too in Stafford, England.
Great first post & a great choice for your first car. Enjoy:thumbsup:
:welcome:
