Zac
- Jul 20, 2020
Hi everyone
quite a simple one.
After just fixing my dash illumination fault (headlight switch)
I noticed the little headlight/sidelight indication bulb had blown. So I replaced it while I had the vent out etc.
Now I'm just wondering if this is correct....
It illuminates on the second position of the ignition. I.e. turn key click once click twice, and it is constantly on even if headlight switch is not pulled out.
I guess this makes sense as it is to merely show you where the switch pull is in the dark!
Just wanted to clarify that it should always be on when ignition on pic below....
Thanks for your help folks
