Anybody experienced the headlamp washer (Offside in my case) leaking and draining all the fluid out of the washer fluid tank? Filled the tank up last weekend and noticed shortly afterwards that water was dribbling from the nozzle. Went to take the car out tonight and no screen washer working as tank empty.
Looked on parts diagram and noticed there is a 'valve' between the pump and the nozzle. Makes me think that it is a NRV of some sort. After lifting the tank away from the inner wing, I can see that the plastic tube disappears behind the inner wing and into the void behind the wheel arch liner and the undertray. So, looks like wheel off, remove liner etc to get at the valve.
Valve held open with debris or something similar letting the fluid draining out is my guess. Any feedback welcome.
New valve looks to be about £16. Just got to find time to investigate.
