Got bored so listed everything I've done so far
Trevor /chedder
Ok so bored waiting for a plane and tried listing everything I've done or replaced on the car.
Brake lines
All disks pads
3 new callipers
Style 68 wheels, powder coated
Fuel tank straps
Frame bushings
Lowering springs
Rear shocks
Radiator
Engine thermostat
Disa valve
Idle control valve
ECU
Plugs
Ht cables
Rocker cover gasket
Fogged airbox
Belts on engine
Viscous fan
Fan blades
Pulley
ABS unit joints re-soldered
ABS sensors both front
Gearbox oil change
Oil change X2
Air filter X2
New headlight bulbs
Clear indicator covers
New windscreen
Changed driver sun visor non mirror
Mini mirror
3d printed rear view mirror holder
Sport seats
Face lift centre console
Android head unit
Speakers front, rear and door
Experimented with BMW subs behind seat
Gear knob custom drilled
Handbrake cover
Recovered steering wheel
Facelift door cards
Window sliders new
Door lock actuator
Wind deflector
Painted roof trim
Bonnet respray
Replacement rear bumper
Replaced broken fog light
Restrained interior black plastic
Door mirror replaced
Spare key
CAT euro 3
Co2 sensor
Exhaust rear section
Spare wheel
Drain plugs
Electric roof repaired, micro switch
New gaiters on gear and handbrake
Handbrake mechanism fault fixed, dust covers
Spring pads
Intake rubber pipe replaced
Water pipes engine front replaced
Drop links replaced
Various bushes replaced.
Still loads to do. 😂
Trevor /chedder
Keep remembering
Interior sill step cover
Door seal
Bonnet earth
Ariel new as old one snapped
New central locking system
You would have been better trying to list the things you hadn't done =))
Thats an impressive amount of stuff.
Stephen
Very impressive Trev.
Trevor /chedder
Out of interest how much did they weigh.
And did you notice any difference in the ‘feel’ or handling of the car?
They weigh loads. Sorry can't remember exactly they are in the garage somewhere. But very heavy and I cannot feel any difference at all. I think changing the wheels and lowering made a bigger difference
