First, let me say that I am having an absolute blast driving and working on this car!
One of the best investments I ever made! And thanks to all the veterans out there that have helped me get the most out of this car.
Now to the question. I had an inspection of my Z3 by the local "BMW pro mechanic" for a general evaluation of the car before purchase (a really good idea and good value for the $100). One of the items he mentioned was replacement of the control arm bushings. Since the car is a '98, I concurred that the rubber bushings are past their useful life. I have ordered the PolyTech bushings and carriers since I do not have access to a press for removal of the old bushing. My Bentley manual says to use the 'appropriate removal tool'. Researching this on the many forums, websites, and YouTube, I have seen everything from using hand chisels, bearing pullers, and even a guy that took a gas torch to burn off the rubber bushing?? Does anyone have a tried and true method for removal of these guys without endangering myself in the process? Also, is the copper lubricant a must for the replacement? One 'mechanic' used a combination of water and dish soap to set the bushings and allowed it to dry in place.
As always, my thanks ahead of time for any guidance you can lend in this procedure.
John
One of the best investments I ever made! And thanks to all the veterans out there that have helped me get the most out of this car.Now to the question. I had an inspection of my Z3 by the local "BMW pro mechanic" for a general evaluation of the car before purchase (a really good idea and good value for the $100). One of the items he mentioned was replacement of the control arm bushings. Since the car is a '98, I concurred that the rubber bushings are past their useful life. I have ordered the PolyTech bushings and carriers since I do not have access to a press for removal of the old bushing. My Bentley manual says to use the 'appropriate removal tool'. Researching this on the many forums, websites, and YouTube, I have seen everything from using hand chisels, bearing pullers, and even a guy that took a gas torch to burn off the rubber bushing?? Does anyone have a tried and true method for removal of these guys without endangering myself in the process? Also, is the copper lubricant a must for the replacement? One 'mechanic' used a combination of water and dish soap to set the bushings and allowed it to dry in place.
John
