Clutch bleeding
Trevor /chedder
Hi all
Anyone got a good link/instructions for bleeding an m44 clutch?
Can't seem to find one
Thanks
A pressure bleeder will work, as the clutch master cylinder is fed from the brake resevoir.
Trevor /chedder
Take the slave off, use some sort of clamp to prevent the pin from coming out too far, and bleed it with the nipple as high as possible.
Thanks Pingu, so am I draining out of the nipple? Sorry can't picture this. Tha ks
On the good old Morris Marina the slave cylinder was mounted in casted ring on the bell housing. Cars came from factory with the feed pipe at the top and bleed screw at the bottom.
Trevor /chedder
Clutch is not responding again. I did drain and replace the fluid, the reservoir is full and I can't see any liquid on the floor. Drove into work fine 30 mins. Then cane back and zero response. May have to leave it at work! Been pumping the pedal for 30 mins and no joy.. any thoughts?
Sounds more like the master cylinder internal seals leaking giving you no pressure when pedal is operated hence no movement at the slave cylinder. No visible leaks will also be a clue to a bad master.
Trevor /chedder
It's happened twice, after the first time it cleared in about 5 mins. Then I changed the fluid using a pressure pump. I need to get under there and have a look. Thanks for the info
