Last year at VanityBMW a few folk had their engines carbon cleaned. Some time has passed now and my question is, was it worth it and was there a notable and lasting difference?
Initially it did make a difference, smoother idle, better pickup and MPG. Just as time goes by, I don't think you notice it and most of the pre-treatment symptoms seem to have come back again anyway.Psychological
There's a business opportunity for you this year then @Lee !When I looked into it you can do it yourself with a can of C02 for £5![]()
That sounds like hard work.There's a business opportunity for you this year then @Lee !
How much does it cost each time and how often is it recommended to do?I've looked at this and wondered whether it is just another "snake oil".
some audi guys did some fairly thorough testing in this thread
http://forum.rs246.com/viewtopic.php?f=35&t=117463&start=120
which kinda makes me think it is a fad, but I really would like to be proven wrong!
They offered this service at Vanity for £75 on the day. You could actually hear the engine note change as it was starting to breath easier.How much does it cost each time and how often is it recommended to do?
Cheers Lee, did they say how regularly you ought to use it?They offered this service at Vanity for £75 on the day. You could actually hear the engine note change as it was starting to breath easier.
Its a mix of hydrogen and oxygen.What was the compound being used again?
Not off the top of my head mate. It was a while ago now.Cheers Lee, did they say how regularly you ought to use it?
could the note change be just as a result of adding hydrogen to the combustion process though?They offered this service at Vanity for £75 on the day. You could actually hear the engine note change as it was starting to breath easier.
IIRC Terra clean utilises negatively charged particles not a gas as such.Its a mix of hydrogen and oxygen.
P.S - Dont confuse this with Terra-clean thats a different process.
I would of thought that but the engine note kept changing along the 30min process. He also takes a reading of what air the engine pulls in, it all seemed to tie in together as the engine began to free up.could the note change be just as a result of adding hydrogen to the combustion process though?
Terraclean is fed through the fuel system, This carbon clean is fed through the air intake so both process clean different parts of the engine.IIRC Terra clean utilises negatively charged particles not a gas as such.
