I am trying to understand how to use a single warning lamp in an ETB speedometer to function for 3 possible triggers.
The BMW instrument cluster has individual warning lights for brake fluid level, brake pad wear and handbrake warning light. The ETB speedometer I am using has a single warning lamp for brakes, and therefore you have to choose which of the three warnings is most important. I would like the light to come on if any of the three sensors are activated.
I believe that it is possible to connect the three individual signal inputs from the BMW loom to the one lamp in the speedometer by adding in diodes to the 3 connections.
My understanding of all things electrical is close to zero so does anybody understand how these diodes can be connected to achieve this? I understand they are directional and will restrict the flow current to one direction only. But I don't know which way the current is or should flow in the Z3 cluster!
On my Year 2000 Z3 I have identified the cables into the instrument cluster for the brake lamp warnings.
Connector X16 (White) pin 17 has a blue brown yellow cable which is for the handbrake switch.
Connector X16 (White) pin 18 has a brown violet cable which is for brake fluid level.
Connector X16 (White) pin 19 has a yellow cable which is for brake pad wear sensor
The ETB speedometer has a single black and white cable which is the brake indicator lamp.
I have found a document from somewhere which has a diagram showing the diodes although the wiring colours do not match those on my car (so I am considering the pin numbers to be more accurate). It also shows a connection to the ground supply for indicator and warning lamps (pin 3 on X17, brown cable)
