#ZedShed Boysies’s Z3M refresh (Only 34k miles)
We have a right treat this week. @Boysie has been waiting patiently since last year for a spot in the shed. We knew his M would be a joy to work on due to the low miles. The plan of attack for his M was to remove everything and refresh what needs replacing, this shouldn’t be too much due to the low miles. We’re also only going to powder coat the smalls, so not the trailing arms and beam. You’ll see why.
First up we treated the shed to a new floor, the first time in 7 years. This should work perfect with such a clean Z3M.
Assuming the normal position.
Look how clean the bay is.
and the miles, oh my god!
once I’m the air we get a good look at the condition of everything.
Crazy to see the original factory markings.
First item we removed was the body brace. This is the smartest and tidiest body brace we’ve seen. It sits flush to the car chassis.
It was held on with a 29mm sleeved nut!
It bolts on under the front belly brace.
Some serious metal work. This will go off for powder coating and Ray can decide if he wants it on or kept off.
Now the brace is out the way we can start to disassemble the rear. First up we removed the arch liners showing the beam bushes completely toast sat on the beam. 34k miles means nothing with 23 year old rubber. The beam must have been banging on the plates.
Bush split.
Starting to remove the rest of the hardware.
At this stage we were only just over an hour in and ready to drop the subframe. It’s amazing the dIfference clean nuts n bolts makes. One subframe
Not much left underneath.
only being an hour half in we decided to strip the rear. We also made the decision at this stage not to powder coat the beam and arms. The factory rubber coating was still pristine. First arm being stripped down.
The under side coating.
Passenger arm.
We then removed the beam bushes.
these were shot.
5 min wipe down of the diff.
Top side.
Old fuel tank straps.
Not actually that bad. Still will fit the upgraded Mazza straps.
Giving the rear an inspection.
Diff hanger looking factory fresh.
So at this stage we were only 2 hours in so we decided to remove the gearbox ready for the shift pin replacements.
Parts building up.
We’re planning to powder coat everything else like springs, roll bars, brackets and roll bar caps. The pivot arm and release bearing not looking to bad, be mad not to replace them while they’re out.
Again it was only 3 o’clock so we decided to strip down the front. When this goes smoothly it’s only an hour. Front hubs.
Wishbones and track rods left, ball joints feel good on these so no point replacing.
This completes the hardware removal, tonight will be a big parts list order and plan of attach for next week. This is a record for us in the shed. We’ve never done this much in 5 hours before.
pgunter
Winchester
2.2i Sport Zedshed Special
Great work from the A team. A great enjoyable day And that Zed is a dream to work on.
More good work from the ‘ Crew that Do ‘ :thumbsup: :scorecard:
Dino D
Kent
2.8 Manual
That’s impressive- look at how clean that diff still is!
Very impressive for a UK and must be garaged properly?
The bushes expected but still surprising how knackered that beam bush was.
so the big question- how does it drive compared to a 100k snotter;).
Engines probably still a bit tight :whistle:
Bazza
Verwood Dorset
Amazing condition car with low miles 😳 but still needs the magic touch to bring it back to near perfection. :thumbsup:
Paul Rice
Doncaster
Z4 2.5 E89 23
Great write up Lee as always but kept waiting for the "but" as each job looked a pleasure! Nuts and bolts behaving themselves thought it was only a matter of time for the one awkward begger that refuses to budge. Hope everything else goes as smooth, mind you i do hear you like a challenge?
Yeah I do love a challenge, the last few cars have all been testing in different ways. Nice to have an easier project from time to time.
Boysie
West Chiltington, West Sussex
M Roadster S50
Bush split.
At this stage we were only just over an hour in and ready to drop the subframe. It’s amazing the dIfference clean nuts n bolts makes. One subframe View attachment 180421
Passenger arm.
these were shot.
Top side.
Giving the rear an inspection.View attachment 180449
Parts building up.
What I can say wow,
I’m so pleased my bit of pampering over the years has paid off,
You are doing an amazing job Lee 👌,
Unfortunately pampering doesn’t stop age affecting things that perish,
My car really does deserves this being done, the ///M’s are amazing cars 👌, and I’m privileged to own one, it’s now twenty years plus.
I’m watching intensely this thread and the amazing progress,
If only you lived up the road from me. 🙄😆
Boysie
M Roadster S50
Possibly not its high mileage at 50000 :ymdevil:
Mark get your car booked in with Lee, no cleaning before you take it there 🙄😆, only joking
I’m sure Lee would love working on another clean car.
BillH
Brilliant what you guys can do in a short time - all that experience and knowledge - respect 😳 I can't guarantee such a clean underside but I've been polishing the bodywork!
Boysie
M Roadster S50
What magic touch would that be 👌
Another good write up @Lee .
You guys definitely got this stripping zeds apart down to a fine art now.
Just goes to show that even a clean low mileage zed still needs subframe bushes.
So I take it we can all say if our subframe bushes haven't been changed its pretty much a given that they will need done if original no matter how clean your zed is.
It’s been a waiting for parts kinda week. They’ve finally started all pouring in. Bits from the powder coaters are in aswell as the majority of the parts from BMW, just a couple of bits left to arrive.
Powder coated bits looking amazing.
New discs all round compliments of BMW.
Also a ton of parts. Still got a few more bits to arrive.
